Hey gang,
97SECB grounding question.
I get the point of braided copper wire and to go to the bike frame under the seat but where does the other end attach?
The antenna mount is just that, a mount for the base, I don't see a ground for the base at all where it connects behind the arm rest pocket.Should one be attached here???
The CB cable comes out the middle inside of the base and goes directly under the seat and plugs into a connector that then runs to the back of the CB. I don't see where a ground wire could be attached along this path.
Mybike has the small vertical plate in the trunk, should I use one of these mounting screws to attach the copper braided wire to?
Also considering putting a foil plate in the trunk under the carpet and attaching that to one of the plate mounts.
What am I missing? :baffled:
Toy4Rick
Hey gang,
Toy4Rick
