Recently, static problems have developed in the cb radio. With the key turned to acc and the engine off... there is no problem. With the engine running and the bike not in motion... there is no problem. Even at high rpms, if the bike is not in motion... there is no problem.
As the bike begins to move, the static begins. The faster you go the more static there is. When the bike is in motion and I am transmitting, others say sometimes there is static and sometimes there is no static. When the bike is in motion and I am receiving, there is always static. After bringing the bike to an abrupt halt, it takes about three seconds for the static to reduce to nothing.
With the bike on the center stand and in gear with the rear wheel turning... there is no problem. With the bike jacked up, when trying to spin the front wheel by hand, there seems to be a low static noise.
So there appears to be a connection between the static in the cb radio and the front wheel in motion, however it is questionable. The cb radio appears to be grounded properly. I have switched antennas with another biker which results in no change. The radio was originally purchased from the Honda dealer when the bike was new.
Any suggestions would be appreciated here or at [email protected]
