1 - 13 of 13 Posts
I just bought a 76 wing and for the life of me can't get it on the center stand. It's not that I don't know how. I've got an 1800 wing and an additional 76 wing and both of them will pickup on the center stand. Any Ideas Rich
Rear suspension too low..bad springs??? Cross member bent/rusted not square tot he bike? First two thoughts
thanks RB, checked the rear shock and is adjusted all the way up.
bent center stand , rusted up joint tube.
push it up on a 2x 4 and see if that helps. (rear tire)
thanks, I'll try the 2x4 trick. The previous owner said he had the frame repainted so I'll have to see what I can see.
on my 1100 i had a heck of a time getting it on the center stand until i changed the rear springs.. i watched the video.. read the files.. thought i was doing something wrong.. now it pops right up. just my .02
Rear caliper is stuck, is bike in neutral?
Oh no... that could be a red flag. Let's hope not!
Does the bike seem to track straight when on the hwy? Does it tend to pitch into a corner one side easier then the other?
I think I would pull the rear wheel and the seat and give the frame a good inspection... and the center stand...
I have my fingers crossed for you! :leprechaun:
JB
Discussion Starter · #9 ·
Well I think I found the problem. The rear tire is a 4.50x85x17. I believe that it should be 5.10x90x17 or close to that. When I rolled it up on a 2x6 and used the center stand everything was fine. Measureing everything with a different 76 wing was all the same except for the tire size. Thanks for the help.
yeah , a undersized tire will cause you to have to lift things up a lot higher . haven knows they are not the lightest . have you checked the front tire size ?
I have three 76s and a 75. They are all different to get on the stand. My yellow 76 has slightly lower progressive rear spring and it is a bear. My LTD hops right up.
Not all bikes are equal to put on a stand.
1 - 13 of 13 Posts
