Merry Christmas.
I have no further words of wisdom than the manual shows you how to do the repair. They are a pain, that is for sure. For the low beams if you turn the handle bar to the full opposite side you are working on and look down through the fork tunnel you can see the plug and large dust cover, and a pen light wedged down in there for light helps too.
Also wipe even new bulbs off well with rubbing alcohol . And wear rubber surgeons gloves while installing them, they will last a long time that way, otherwise they tend to burn out quicker, just one fingerprint will cause them to run hot and burn out quickly.
As for the high beams, those will really try your patience.
Maybe you could hang some weights on your fingers and stretch them out a bit .
Kit
