I have seen this topic before but never decided to read because ( I dont have that problem)
Heres the situation. I cleaned the carbs last year and couldnt register the bike. I let her sit for 3 months before trying to jump with a car battery just so I could move it elsewhere.
Today 7 months later I drain the oil and was supprised when my usual oil collector started overflowing.:shock:It smelled of gas and was realy thin. The petcock was left on open but it is the aspy with no res position on the petcock and electronic fuel pump.
After draining and installing fresh oil and filter I changed my timing belts and noticed that the left side was one tooth off.
could this one tooth off be the reason fuel kept draining into the crankcase.?
I also have used jumper cables to give me power as I replaced my radio. Does this fuel pump prime while the switch is on. If so I may have flooded the cylinders with fuel and cranking her before may have forced fuel through the oil rings.
