what do i need to change the brake and clutch fluids in an 1800. new to working on a bike and have no experience. Thanks
I use a MiniVac, the kind you can pickup at any auto supply store. Works great and is a 1 man operation. Just make sure you don't run the master cylinders dry.
Firstly a manual as the brakes need to be bled in a specific order.
A speed bleeder is an asset for bleeding the brakes.
You need to take off some lower panels to get to the clutch bleed nipple.
You have 8 places to bleed. Brakes are two per caliper, four total on the front, two on the back, one at the anti-dive and one at the clutch.
Speed bleeders are nice, but a bit expensive, but those with the use of a clear section of tubing do turn things into a one man job. Especially the one at the clutch and the ones at the rear caliper.
This device also works well as speed bleeders are about six bucks each.
Motion Pro - Hydraulic Brake Bleeder
Kit
