I have a 2012 Goldwing GL1800 and would like to modify the front indicator lights to stay on permanently as this adds to visibility and when the indicators are turned on then the flash off, is this possible and if so how do I do it?:praying:
So you want them to be running lights as well as turn indicator lights, right ?
You will need to get hold of the US spec front bulb holders. They take a dual filament bulb which allows for one filament to stay lit. Once you get that, run a feed wire from your headlights running light to the low wattage side of the bulb holder.
You might want to check local laws before spending the money. In some countries it's not legal to have amber posers in front.
Also, the posers are wired through the turn signal switch so they turn off when the signal is energized.
You don't have to wire them that way, I guess. Just information.
