1 - 14 of 14 Posts
Banned
Okay people I have a delimma I need your advise on. I will soon have to put a new tire on the front and rear of my GL-1800. I have the two tires at home. Dunlop Elite III. Since I have Centramatics on both front and rear what tools will I need to get the tire off the rim without scratching the rims. Where can I buy them and do you know anyone in the 95366 zip code that does this or has the tools at thei home to get this done. I have all the tools to get the assembled tire and wheel off the bike I just need to know what to do to get the old tire off the rim and the new ones on without doing any damage. Thanks
Any tire shop there in Ripon with a modern rim clamp tire machine can do it. They may not want to but they can. I do it for myself and my friends motorcycles.
You could lag bolt it to the wall instead.
I change my own 1800 tires, and did the first few with a Harbor Freight changer. More recently, I bought a Coats 220 from a biker friend, and it is a much heavier machine.
While viewing your link, I had to chuckle at the picture of breaking the tire bead. That short handle will never break the bead on an 1800 rear tire. I'm not saying the machine won't work, but changing tires on an 1800 is not for the faint of heart......
get tire spanners soap/water...valve remover..and i break the beads on my miiling machine....easy!!....using as a press to break the beads wich can be so much fun!!...getting them on you must make sure the opposite side of the bead is on the inner lip center area both sides to flip the edge(your trying to get on) of the bead in... with the spanners...use nothing sharp like a monster screwdriver....i find 3 spanners work good but 1 set and a third blunt pry works...you cannot scratch the sealing diameter or it might leak and to balance use jack stands with the axle and stick on weights...now this job still takes some muscle...but much...much less if you do it exactly correctly...some rice rocket tires are so soft i did them with my bare hands....but not the big tours...
grambo, did you ever change an 1800 rear tire?
The reason I ask is that changing the rear tire on a 1500 is a piece of cake compared to an 1800.
Vintage Rider
I have never changed an 1800 tire, so I have no idea what they are like. I have always changed all my own tires BECAUSE I don't want some shop tearing up my wheels. I recently swapped a 1200 rear tire from one rim to another, it took about 15 minutes, tools were a valve core remover, two 10" tire irons, some WD-40 in a spray bottle, and an air compressor.
I have changed all my tires. A bead breaker,valve stam remover,
two tire spoons,soap and water in a spray bottle. Dulap E-3 and Bridgestone 704. Dulap were easier.
I use one of these, makes it real easy. A little cost prohibitive though.
data:image/png;base64,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
Mondolfo Robofit
Banned
Discussion Starter #10
Some of us just have a whole lot more money than others. Thanks for the input. I'll be taking mind to a local honda shop.
It's not mine, if that's what you are thinking. It is what I meant by " modern tire machine".
Banned
Discussion Starter #12
Oh, my mistake, I thought you may have bought this and installed it in your home garage. Take care and have a great night.
The Honda shop in Modesto charges $25 per tire if you bring the tire and wheel in.
If you buy the tool (and share), I'll let you use the hitch on my truck....
Generally, I use a bench-vise to break the bead and just use tire irons to get the tire on and off.
Banned
Discussion Starter #14
Good information. I will save myslef some money since they are closer anyway than Stockton. Do they do it on a walk in non appointment sit there and wait basis?
1 - 14 of 14 Posts
