78 Gl1000. After reading feedback that ignition is primary diagnosis for my rough sounding/dead cylinder, I'm wondering if my higher secondary resistance reading from one coil is due to a shorted/exposed (yellow) wire at the coils, the one leading from the points/ignition (electronic). This would make sense, no? Can I cut/reconnect that (short) length of yellow wire to the coils for better conductivity? Maybe that's my problem. The wire abuts the air box intake, so maybe the exposed part of the wire is shorting to ground on the airbox?
Also, should I test the stator?
