Hi guys and thanks in advance for any and all advise. My 86 SEi has 25K and I bought it new. The volts suddenly went off the dial and from what I read, it sounded like the rectifier went bad. I bought an aftermarket job from a supplier in Canada and at the same time decided to eliminate that troublesome three wire connector just in front of the battery.My solder joints seem solid, but I'm no electrician. Everything seemed fine for around 100 miles, then the volts went the other direction (steadily dropped)until the battery was sucked dry.When I attempted to seperate the two yellow wire connector near the rectifier (to check for continuaty), I discovered one side of the connector had began to melt to the wire from what I assumed was a bad connection. I cut the plastic away and removed the plastic housing from bothset of wires. I checked for a short in the stator and found none, as all three wires had continuity with one another, but none had continuity to ground. I then re-inserted the male ends of the connectors into theappropriate female connector (I marked the wires before removing them) and pinched the female connectors tight against the male connectors to ensure a good connection. I started the bike with the help of a car battery jump and the voltage read 11.8. It remained at 11.8 or 11.9 with or without the car battery jumped to the bike's battery. Afterless than fiveminutes, I grabbed the wire connection which I had reinserted into the plastic housing and wrapped in electrical tape. YEOWWW!!! HOT HOT HOT! With my low batt, the thing shold be puttn out 13+ but it did no beter than 11.8. Any ideas on what's going on here? Should I run new wires from the solder joints up to the rectifier? Do you think my solder joints are bad causing too much resistence? Like I said, I'm no electrician! Thanks again, Gary.
