Hey I have a 1980 Gold Wing, 47,000 miles. Off of cold start, the amp meter reads output at around 13.75 volts, Then after running down the road for about 4 minutes, the output goes down to a little under 12 volts. ?Is this a stator problem or is it possible a diode in the regulator stops working once it is warmed up. ? Is it possible the stator is not working on all outputs legs. Any help would be greatly appreciated.
Thank's RT
Thank's RT
