My turn to ask an opinion
After all my stator /charging problems settled down I installed a digital voltmeter into the bke(86 Asp) to replace the crap hondaline in the right fairing pocket cover
Anyway I find at 3500-4000 rpm I am getting up to 15.1 vdc
at idle 13;6-13.8 vdc apply the brake lights and it drops to 13.4-13.6
I am now concerned about overcharging the battery or is this normal voltages??? Opinions please
well I went from no charge to this and if all I have to do is keep an eye on the battery levels great
Neil
Neil, I don't know what to tell you.Two of mythree 1200 manuals give a normal voltage range of 14-15 volts at 3000-4000 rpm's with a note that anything over 15 volts is borderline for regulator correct operation.
If it's any consolation, my 1200 puts out the exact same as yours & that is 15.1 volts at anything over 2800 rpm's. It's been that way since I redid the charging system connections & hard wired the complete charging system. I have a AGM (glass mat) battery & so far it's holding up fine (about 9,000 miles since charging system rework).
Twisty
yeh thats what my manuals say as well so I thought I'd ask the guru's
See what happens when you clean up all the connections as a side line to tracking down problems
Neil
Neil,
My '85 Aspy has stock stator hard wired including st the regulator. I have never seen it get above about 14.5 Volts.
At idle (1050 rpm) the battery will discharge with the brake lights on, below 12 volts sometimes.
johnmac wrote:
Neil,
johnmac , where are you monitoring the voltage at (where is your voltmeter connected)?
Twisty
I stumbled onto this post while seeking solution to my 15.18 volts at 2000 rpm. I read another post that indicated the regulator reads the ignition voltage which in turn calls for it to charge. My voltage was ok (13.8) --- I was curious where the regulator gets its ground (case?) and I removed the 2 bolts that hold the regulator and found them to be corroded. After cleaning bolts and mating face of regulator, I am at 14.8 at 3000 rpm. I am guessing that the case ground was creating resistance and sensing less that 13.8 v . (When I measured the voltage '13.8' I had a test lead on the battery ground)
Ride Safe
A voltage regulated to 15 VDC or 15.xx VDC is considered normal for the high end. Crap, corrosion, dirt, scum and all kinds of things have differing electrical anomalies around a DC voltage. These dirty conditions can add or subtract a charge onto the system...best thing to do before panicking is to clean and make the system as new as possible. That means all wires, connections and devices should be cleaned and all foreign matter removed.
Make the electrical system as important as the motor and make it routine.
14.0 - 14.7 @ 3000 RPM's on my '84 Aspy with the stator connector removed and the dreaded 3 yellow wires soldered together.
