chattering when starting off in first
982 Views 21 Replies 15 Participants Last post by  zimmerleemark
I was wondering what could cause my 82 aspencade to chatter when taking off in 1st. If I rave up the engine and the let the clutch out it seems it reduce the chatter also traveling around 30 MPH and in 4th gear it chatters unless I down shift to 3rd were the RPM's are of course higher the no chatter. Any idea's?:?
Thanks,
Bailbob:waving:
1 - 20 of 22 Posts
got to have your revs up starting off also as speed decreases need to lower gear to keep rpms up, your moving a whole lotta bike and you to.:action:
Thanks thats kind of what I thought, but I wanted to be sure I was thinking right and not something I needed to address.
Just a thought or two...there must be a little freeplay (free lever movement that does not disengage the clutch, ~1/4") in the clutch lever when it is all the way out.
If you have that freeplay, and it still chatters, you might want to try a Seafoam treatment. Some folks seem to believe in that MMO (Marvel Mystery Oil). Either way, you dump it in the crankcase for the purpose of cleaning outgooey buildup. :waving:
Also what engine oil are you using?
Thanks, I use Castrol GTX 10w40 motor oil. I will try adding the sea foam to it and see if that helps the chattering on low RPM's
Its normal.
Mine does the same thing.
You need to keep the RPM's up a bit.
When was the last time carbs were synced?
Is the passenger chattering in first? tell her/him to wait till your in top gear. :)
Jim and Lee wrote:
Its normal.
:coollep:Have to agree with Jim and Lee on this one,
Mine has done it since I bought it 10 yrs. ago, a few more rr"s in low gear takes care of it, and when I'm down to 40-45 I'm in 3rd or 4th gear. Just my .02
Winger 82:11brown:
Thanks Winger 82 Thats what I have found out also, what a relief I at 1st thought something was wrong, I guess I will sleep well tonight knowing all is well!
You might be running a little rich. When my bike was running rich it would chatter in first gear and lug at 2000-3000 rpm. Check if you have any black smoke coming out of your pipes. Also it can't hurt to make sure your carbs are synced properly. Of course I could be wrong but kind of sounds like my problem before. Hope everything turns out great!
When I first started to ride a wing, I found I had to give her a good amount of gas to aviod what I called the "Death Rattle". It improved greatly when I synched my carbs. I still get it if I get caught going too slow in too high a gear.
Now that I have my carbs synched and have given them several cleanouts I find I can take off at about 1500rpm without the death rattle. Prior to getting the carbs right 2000rpm plus was required.
I agree, Its normal. You just have to give her a few more RPM's at takeoff and be aware of your tach when you are riding up a steeper grade. This bike needs to be downshifted a lot to run optimally especially if you ride 2 up. As far as the carb synching stuff, if it runs good, just ride it. Try some seafoam though, put half a can into a full tank. It will make a difference.
Check you're plugs to.Had the same problem changed my plugs runs fine no rattle.Just an idea, my plugs looked fine.Hope this helps.
carbs need syncing
mark:waving:
My 82 wing does the same thing if I dont give it enough gas during take off. I think its normal but it does sound terrible. It's a big bike.
That is an Awesome new/ old bike VA.GENT. Looks comfortable. What year is it?
1 - 20 of 22 Posts
