I just edited out everything that I wont need for my cafe build and wanted to see if I am close. I only had 2 spots that I really question which you can see on the schematic. Any tweeks or advice is greatly appreciated. Instead of a fuse box I am just going to use inline fuses and will most likely end up re wiring it from scratch but for now I am just trying to eliminate excess and get it to start. Thanks
rayworx wrote:
Where does the brake light get power from??? I'm not seeing a link to 12v
The same goes for the rear tail light I see no 12v power to it either.
Banned
Future food for thought from a quick look, ... a one-piece regulator/rectifier from a newer bike like a small Nighthawk or something would elimate the two-piece set-up used in the original GL scheme.
Thanks guys. I got carried away and started erasing the 12v lead from the brake light. Thats why I put the question mark, wanted to see if there was a spot to tie it in.
Thanks CM85. I will definitely add that to the list. Simplified wiring makes everything easier.
