Thought this might help someone else so here goes. My 99 GL1500 SE has those shiny chrome levers for clutch and brake from Kury. I did not have any free travel on the clutch side, after much thinking, (boy, did THAT hurt) I thought I'd
try something. I took off the lever and measured the length of the push rod, 41mm's on the button. I made another 'test'
push rod from rod stock and ground it carefully to 40 mm long. Installed it and BINGO had free travel!! So then I ground the end of the oem push rod carefully on a sander and installed it. Now my clutch feels much better! I am happy with this now. Just a minor modification that is very easy to do.
Thanks for the information. Good idea and well stated.
The only little problem might be that the bushing or master cylinder piston might wear a bit faster. I bet Honda not only has a precise length but a specification for the finish. Not that I would worry but the first thing that popped in my head as the bushing wears out with the Honda parts.
I did polish the ends very carefully. Look just like the oem ends when I got done. Use very fine polishing belt or wheel. Everything else works just fine, cruise set and disconnect. All lights and so on.
Limpy,
I never thought it was a big deal and I probably shouldn't have even posted but it just popped in my mind. I'm sure it will be just fine. 😎
