1 - 9 of 9 Posts
What's the accepted method for doing this. I get a pretty good "whoosh" when I remove the tank.
Piaggio MP3, was 02 GL1800
Remove the tank Andy? Or just the cap :D
The whoosh is most likely a vacuum rather than air escaping under the cap. If the cap vent is plugged up, as the gas level drops, it will create a vacuum in the tank.
Hey Lopeha,
I used to have a sputtering problem near ½ tank and below before I fixed my gas cap. I simply took it off, tapped it with a hammer for a bit. Put in a bunch of WD40 and let it set for awhile (15 – 20 min) and then started tapping it again. I then smacked it a few more times a bit harder on the concrete floor in the downward position (oriented as if it were on the tank). Problem solved. Not only does it not sputter anymore at ½ tank… The bike overall runs better at about 7/8 of a tank and below.
Tim
Hey there lopeha I put about 1/2 container (plastic butter container 1lb) of seafoam and put the cap in and left it overnight works perfect.
i do belive they are the same--vent wise--but they (1000) are smaller .
I wish that I had a good cap or a great answer for you brother. I received the taillight that you mailed me for free today and would love to return the favor. God Bless
It is supposed to hold some pressure so the whoosh is normal. If it's a vacuum in the tank then it's plugged. Soak it in vinegar to remove rust.
Discussion Starter · #9 ·
Great ideas! Thanks for the response. I'll try them tomorrow.
1 - 9 of 9 Posts
