Well, probably just a dirty switch or the solenoid is going out on my 95.
Probably solenoid.
A few times yesterday I had to hit the starter button about 10 times or more and each time I got a nice solid CLICK sound but no starter. It happened a couple times on my CA. trip also but only took 2 or 3 tries to get starter to kick in.
Pretty sure the solenoid as I also had a rare problem a couple times it stuck and kept the starter cranking after the button was released.
Looks like I am going back to push starting again for awhile. Fond memories of the 88 LOL
Actually I do have another solenoid and starter etc.. here so no problem other than swapping the parts when I get the time.
I jumped on my bike the other day, and hit the starter switch, nothing happened. Hit it again, nothing, and again. Looked at my right hand and I was pushing the Set / Decel button instead...
More than once I've done that....
i jumped on my bike the other day, and hit the starter switch, nothing happened. Hit it again, nothing, and again. Looked at my right hand and i was pushing the set / decel button instead...
More than once i've done that....
Been There Done That.
Chromo doesn't feel right if he isn't push starting his ride, he's done it for so long it's become a habit! ;)
Yep. I miss my 88! :ROFL:
I'll fix it.
I did for the heck of it push start, the 95 is a bit harder to get rolling than my 88 was but still got it fired up in about 4 feet same as I could do the 88, so no problem there LOL
Not sure why it seemed harder to roll, I got 45mpg on that tank of gas so not anything sticking or dragging. I got every drop of gas into the tank that would fit also so no chance I did not fill as full as other times. I was running mostly 55-60mph for 200 miles that tank, Branson Breakfast.
One real big difference between the 88 and 95 I do not like is that the 95 must be running or reverse will not work. I liked the 88 being able to use reverse with engine off!
CHANGE ENGINES!!!
:lash::lash::lash::lash::lash::lash::wtf:
