Visit your doctor immediately, The Cub!!!
Pete
Hey The Cub... Let us in on a little information... What bike do you have? year, make, model.. mileage...
What shape are the tires in? We need input....:bananas:
Old School Guru
Welcome to the forums thecub!:clapper: It sounds like the u-joint in your drive shaft may be bad, or a warped rotor.:pumpkin: Since it only does it when you start off, could be just normal wear in the drivetrain. A bad u-joint will click almost every revolution when you let off the throttle, a warped brake rotor will cause the brake calieper to move back and forth while moving also causing a clicking sound.
Gene:waving::11red::11red::11red::cooler:
Again... (yawn) Let me ask.... How many miles on it?... What shape are the tires in?... Is the "click" happening when you let out the clutch??? Is the clutch already out and the noise happens when you're accelerating?? Give us some history on that beauty.....Come on The Cub... Let's have everything you've got.... PLLLEASE!!! :bowing:
