I'm leaving on a trip monday morning. I changed the rear end oil and when I put it in gear when running there is a clunk in the rear end when running on stand. You can move the wheel back and forth a little about 2" not side ways when it is not running but in gear. Is this normal. I don't want to lock up at speed.
Help!
You do get a fair amount of back and forth movement as you describe. Mine's like that. You also will get a bit of a clunk clunk noise on the centre stand as the wheel can rock freely with the slight pulsing from the engine not being under load. Is it ok when on the road?.....Steve
