1 - 9 of 9 Posts
Tried looking in the book... found nothing. Sounds like the clutch and trans
want to fall out of the bike. Goes away at around 1,500 rpm can anyone
tell me how to correct this? davestude at hotmail dot com
thanks
Dave
P.S. add the .com to the e-mail address
EDIT: further broke up your email address. To keep trolls from spamming you.
02 GL1800 w/Auto Pilot
Which bike? You have two in your profile?
However, if the carbs are out of sync, that is a common symptom. Especially noticable on the 4 cylinder wings.
If it pulls smoothly from around 1500 rpm on up, most likely it is carb sync.
As severe as you describe it could be synch but also could have a dead jug. Sart up from cold and with a small squirt bottle of water monitor your header temps to see if all 4 ? are firing correctly.
Oh yea thats on my 1976 GL1000, sorry I tend to think fasterthan Itype.
Stude wrote:
Wouldn't the vacuum gauges reflect a dead cylinder?
Not necessarily--it would depend on whatcaused the cylinder to be dead. Not that familiar with the 1000,but out of sync carbs(as suggested) may be causingthe primary chain to jump around, and thatcould be what you hear.
Idle is a bit slow I'd adjust it up a bit to say 1050. Also check the timing. If its too early it will knock.
Sounds kind of normal and its just a bit out of tune.
Suggested idle speed for a 1000 is 900 rpm. With the carbs in proper sync, it'll idle smooth at 700 rpm
Sync them carbs and run some seafoam in the gas ---you will be amazed!!!!
1 - 9 of 9 Posts
