What do I use for clutch fluid? Does it just use brake fluid or???
If it is for a wing clutch, Dot 4 yes.
If it has been more than 2-3 years since it was flushed, you may need to remove and clean the master cylinder and slave cylinder before bleeding, as gunk gets built up in the seal grooves, especially in the slave cylinder grooves and leaks start happening.
Oh - THAT guy...
As said above.
Use a syringe to draw out the old fluid, replace with new and flush it through keeping the reservoir fullish.
