Tool loan for a 1983' GL1100 "Clutch holder tool"
I need the clutch holder TOOL, so that i can torque the clutch nut to the required 44 ft lbs
or if someone knows where I can get one of them reasonable.
Westgl
thanks dhrith,
But my engine is out of the frame.
I found a better way to hold the clutch, and keep it from turning.
Dis-assembly is not the problem.
This works great for (The Hard part) re-assembly.
Get three washers, put three springs on, then put a washer on each of the three screws tighten them finger tight.
That will hold the clutch, then, have a friend use a 19mm socket on the front crank pulley bolt.
Next you will have the socket/pipe tool that you made to torque the clutch nut.
it was that easy, this way you dont need a tool to hold the clutch basket, just the tool for the clutch nut torquing.
westgl
Ahhh ok, sorry. I was a little confused and assumed you'd meant the nut tool not "actually" just holding it in place. ;p It didn't dawn on me until after I hit send you "might" have meant exactly as you said just for that reason. ;p
