1 - 16 of 16 Posts
Hi, I am a new member and new to riding. Purchased a 1999, 1500 SE in 2010 and really enjoy riding. I did run into an issued last summer with the clutch. There are times, randomly, when the clutch lever will not compress all the way.. Clutch depression is varied, and is solid and anywhere from almost just enough to shift to complete compression and anywhere in between.. I have asked all the people here that ride about this and know one seems to be able to give me any help as to solving this issue.
There are times when I have a hard time shifting.. I checked the Master cyl. and it is fine, Could be the slave or could be the clutch piston or could be in the transmission.. But were does one start and what am I looking for.. If anyone has experienced this and can help i would appreciate any information.
I do have a second issue. That is the fuel consumption of this year/model.. It is not good at all.. I realize that the hotter the day, the better the mileage, but if I see high 20's, that's the best & it should be better.. My mechanic used hotter plugs and tuned up but not much better..
Thanks in advance to anyone that can help me.. ELK
Hello and Welcome to the forum :waving:
Now pull up a chair and make yourself at home :applause:
Elk try posting your question in the tech section
I am sure the lads there will sort you out,
Here is a link http://www.goldwingfacts.com/forums/forum1/
:waving:Hello ELK and Welcome . Have you flushed out the DOT 4 fluid in the clutch and bled the system ? The fluids in the clutch and brake should be flushed out every couple years . Another thing that comes to mind is if the hose might be breaking down internally , and it blocks the fluid .
Gregarious Greeter
[align=center]
[/align]
[align=center]Welcome ELK[/align]
Welcome from Oklahoma :waving: Enjoy the wing :cheesygrin:
I recommend you post your question over in the technical section. Most of the gurus won't see it over here.
:waving: :waving: :waving: :waving: :waving: :waving: :waving: :waving:
Hello from Virginia,
Welcome Aboard!!!!!
Glad to have you with us!
Welcome, WelcomeTo Steve Saunders Goldwing Forum.If you have any questions no matter how trivial they may seem this forum is the place to ask them. What I have noticed is that some of the people here were :15red:'sin their previous lives and can answer any question you have. Theforums that I get the most from are::
Goldwing Technical Forum
General Motorcycle Discussion Forum
These have the best info aboutGoldwing’s and are where you ask questions and can get help..
For Sale/Wanted ForumGood stuff for Sale or if you have old parts sitting around the garage you would like to get rid of....
:18red::15red::12red::11red:
And when all you need is a good laugh to start your day try the:: Fun Forum After that it’s up to you which of the others you will like the best all I can do is suggest.
Again Welcome to the Forum...
Oh and did I mention everyone here loves pictures.. Show us some of yours... Even if it’s not a Goldwing just a pretty view
Welcome to the Forum ELK! :waving:
[align=center]:action:Welcome to the greatest forum on the net:action:[/align]
[align=center]
:action:Welcome from the "HOOSIER" state:action:[/align]
WELCOME:waving::waving::waving:
Howdy from the great Northwest!!:waving::readit::readit::readit:
1 - 16 of 16 Posts
