Well we just got our first gold wing.Seemed to ride fine on the way home,shifting was a little tuff not horrible.Now if you put it in first gear it clunks in and it will slowly take off.Its up on the center stand and the back tire moves with clutch in. Also the lever is all the way pulled in. I was playing with the lever and it seemed to be realllly easy to pull in.It takes nothing at all to pull in.The brake lever feels good little tight to pull.Any sugestions?
Yep, need to bleed the clutch system most assuredly. You might want to do a search on the box above, there is a fair amount of information on bleeding out the clutch, it can be a :cooldevil:to get all the air out.
bleeding the clutch master cylynder is a pain... if you get air in the pump itself you will find yourself doing all sorts of weird movements trying to get it primmed. best bet is to remove it from the handle bars, put the lid on and turn it handle tip up... be care ful do NOT get any fluid on the paint or it can destroy the paint
