My 1500 clutch hydraulics slowly lose pressure after being held in for ~10 seconds. I was going to do a normal vacuum flush but the upper banjo bolt presents a problem there. If I put the bike on center stands with handlebars to the right (so banjo is below master), will a vacuum still clear all air pockets? Would a reverse flush be a better idea in case the air is in the lower banjo bolt? I've heard cases where the line will not want to bleed or flush at all; Would a reverse flush still work in that situation or is that going to be a good ol lever pump job or banjo bleed? Would zip-tying the lever down during the flush help at all or will that risk air pockets in the new fluid?
Also, any tips on where to pick up a large syringe and appropriate tubing would be great, couldn't find a good syringe at a normal hardware store.
