This has to be simply an MC gone bad, seeing how the one off the GL1500 worked fine for you.
1. Just pry it out, you may have to spread out the little prongs that hold it in so it will stay when you press it back in place.Here are a few questions that I need help with....
1. How do I remove the tin protector inside the master cylinder without damaging it?
2. How is the best way to clear the whole under that tin protector?
3. How and where exactly do I check and bleed the line?
4. How and where exactly do I bleed the Slave Master?
