Here is one on E-Bay now. However if the only thing wrong with yours is the sight glass, it can be repaired.
It can be plugged or have a watch crystal put in place of the old plastic.
If you spend the time with it it can look nice. The faded and leaking sight glass is very common on the 1200 clutch and brake masters. Honda only sells the entire master cylendar for a high dollar. When you pry out the old plastic, there are two small aluminum pieces. Don't loose those. Then the hunt is on for the perfectly sized replacement. The watch crystal works best, but no one wants to sell them online unless you buy a case. Some people just use JB Weld and a dime to plug the hole.
Use the search function(look for sight glass).
Good Luck
Good Luck
