Now that you have fluid coming out the bleed valve, pump the lever slow about 5 times, hold it in and crack the banjo bolt real quick. Do this 4 or 5 times and you should get your clutch back. I would run new fluid clear through the system. VERY IMPORTANT - wrap a rag around the banjo bolt so you do NOT spill fluid on anything, it will melt your fairing. The little tank you are talking about is a condensation overflow, just take it off and dump it every couple months or more if it's real humid. Paul
