How often have you had to bleed yers?
that is about the time table I use as wellEvery two-three years at time of fluid change...
Well... Personally I'd check the gasket at the master cylinder first. Take it out and cover the master cylinder, bend the gasket where it mates to the cylinder and see if you can see any splits. If so order another one. Even the smallest split can allow air into the lines.Well, I had it bled when I first bought the bike in June, and recently had it bled again. The guy that worked on it said it probably has a leaky slave down at the motor.
