1 - 3 of 3 Posts
I'm working on the clutch of a 1984 gl1200. I do not have any pressure at the level and the system was bled at the dealership. It worked for a while after leaving the shop but got progressively worse until now I can not activate the clutch at all. Help
Welcome to the forum pbogatko
Sounds like your clutch slave cylinder is leaking, which is very common from not flushing and bleeding the fluid yearly (same with the brakes) . If so, it is full of gunk and the fluid starts leaking into the engine and eventually outside and will eat the paint off the rear engine case. Flushings will not remove the gunk, only a proper removal and cleaning will remove the gunk in the slave cyl.
Please finish your location, there is more than one
"caldwell"
1 - 3 of 3 Posts
