If its motorcycle oil,it should be fine.ive used the mobil 1 in other bikes in the paat and havent had any problems
Sent from my SM-G973U1 using Tapatalk
I'm sure it was the hamburgler.That small hole in the McDonald’s has given a lot of owners nasty clutch thoughts,my 1500 got to slipping in high gear pulling it out to pass,I’d bleed the system ,it would work fine for one day,
Found the slave cylinder was bad and the hole plugged
Lol spell check,I'm sure it was the hamburgler.
I'm in no shape to help, but...
Additives won't cause immediate symptoms like that. May be a problem with the damper plate.
You guys do realize he got it fixed?From what he’s describing it’s the same symptoms my 1500 had
