1 - 3 of 3 Posts
Senior Guru
Hi speedracerand welcome to the forum. If you have to do it from scratch (that should only be needed if you fitted a new cable), take up some of the slack at the clutch end. About half an inch is fine, then fine tune at the handlebar end until the clutch releases about an inch or so from the grip end. Thta´s it. You can usually do all the adjusting from the bar end, only needing to use the clutch end adjuster if you keep running out of thread at the bar end.
1 - 3 of 3 Posts
