New engine is running good but now I have another question. Every since I installed the new engine, the transmission will try to engage while stopped with the clutch lever engaged. It doesn't happen every time but enough to be agravating. It seems to get better in the afternoon when the temperature is hot than it is in the mornings. I have triple checked the cable tension and it appears to be fine (around 5/16th play) and it does disengage the clutch like it should it just doesn't stay engaged sometimes. The transplanted engine had set up for awhile so I'm hoping maybe the plates are a little sticky. I put Rotella 15w 40 oil in it.
