1 - 2 of 2 Posts
84 1200 standard
Hi my 1200 gw coil is shot, I have an 1100 coil that I can swap, the 1100 has a ballast resistor in series the wire seems to connect thru the ballast resistor can I cut the wires and reconnect together not using the ballast resistor in the coil circuit.
You can use the coil but use it with the ballast resistor.
1 - 2 of 2 Posts
