The clymer manuel for my 1987 Asp. 1200 says cylinder 4&2 on one coil cylinder 1&3 on the other coil. on my bike as you are looking forward the plug wires are for cylinder 4-3-2-1 Whats the correct way? Thanks in advance.
Alski
Sitting on the seat, Cylinder #1 is Front Right. #2 is Front Left. #3 is Right Rear. #4 is Left Rear.
The coil wires (looking at back side of coils where plug wires exit) go (from right to left) 1-2-3-4.
If what you say is correct, why does my wing in dirrect opposite of what you say run
so good. And differant then the clymer manuel. We have to figur this out.
Alski
Alski, the clymer is wrong on the coil cylinder supply..
Cyls 1 & 2 (R/ ft- L/ ft) are on one coil & cyls 3 &4 (R/ rr-L/ rr) are on the other coil..
Twisty
Twisty
What I am trying to figur out? On my wing sitting on bike. left coil cly.4 & 3 right coil cly. 2 & 1. Its been this way since I got the bike and it runs good. Is there really a correct way?
Alski
alski425 wrote:
Twisty
Alski
Alski, the side the coil is on really doesn't matter, all that matters is the coil wires from a coil go the the two spark plugs that match up with the side the ign box fires at that time. You could swap coils side to side & not see any difference as long as all the wires going to them remains hooked up to the coils as they are now..
Twisty
The Clymer manual has been known to have other errors as well.
