I thought someone mentioned Honda Belts being Kevlar cord and that is the reason for the cost. So Google and I have engaged in a search for Kevlar cord timing belts for my 87 Aspy.
So far,
Gates NO
Dayco NO
Bando NO
Jason Industrial NO
and Honda is still trying to determine if their 14400MG9004 belts are Kevlar cord or not.
So anyone?? Is there a Kevlar cord belt?
If there is, my research leads me to believe it would be worth it.
And if there is, would the tension settings be the same as ordinary belts?
How is that for a crowd pleasing stumper of a question?
Discussion Starter · #2 ·
OK I just hung up from talking to Paul with Dayco.
First, Paul rides a wing, 95 to be exact and I have invited him here.
Second, he tells me that Dayco does not have a Kevlar cord belt for the application and he would not necessarily recommend a Kevlar belt if they did have one. The Dayco 95070 uses a K Glass cord and is quite adequate. He also recommends changing out the tensioners when you change the belts and it makes sense to me.
So I am going to change out with Dayco belts and change my tensioners.
Makes sense about changing tensioners, but then again some tensioners rarely fail. Many car makers sell belt & tensioner kits and (for instance) some common Ford tensioners often fail at relatively low mileage (under 50k).
Heard back from Honda as well. There are no Kevlar belts by Honda for my machine.
Oh well, interesting study and enjoyed the research.
Hey Eddie, I sent you a pm. I do make it to your town occasionally.
Some how I can't see changing out $80 tensioners if they are still smooth and tight. They are not too likely to fail without warning, I changed the pair on my 93 with almost 95,000 miles on them and they looked like they could go another 50-75k.
Other side of the pond
I wouldn't be too concerned at chasing up Kevlar belts. Kevlar is a bonding material and while it will make the cords in the timing belts stronger, teh rubber won't be any better, ie if you leave the belts unchanged for long enough the rubber will dry up and crack anyway, Kevlar cords or not.
