21 - 31 of 31 Posts
My carbs need to be synch'ed and I was a bit intimidated by what I was reading in the manuals. After reading through your How to, I am no longer intimidated. The only problem is that I now have a shopping list of things to get!
Thanks a bunch!
I dont know of any book that gives better info than you did on this.You should write a manual Your net wing would be paid for free. Do you have one for the wires on tail lights for GL1200A From under the seat to all back lights I have no running lights but everything else works. I also have a add on blinkers on trunk.
What a great job. Thanks does not come close to what you have on this forum
Not to stroke all the fur off you head, but THANK YOU!:bowing:
Between this site and goldwingdocs I have gotten so much information about my Wing that I could not have gotten anywhere else in anywhere near as short a time. I really appreciate All Y'all!
Discussion Starter #25
It just occurred to me that I haven't updated the list on this thread in a very long time. So here, in alphabetical order, is the current list of articles:
Adding LidKeepers to My GL1100
Derusting Your Gas Tank
Easy Grommet Repair
How to add a trunk rack to your bike
How to adjust your valve clearances
How to change your engine oil
How to flush your cooling system
How to get a Goldwing on and off the center stand
How to get the bike up on its center stand
How to install Dyna Beads in your tires
How to lubricate the splines in your rear drive
How to lubricate your (side) kickstand
How to lubricate your center stand
How to rebuild your front brake calipers
How to rebuild your front master cylinder
How to rebuild your rear brake caliper
How to rebuild your rear master cylinder
How to remove and reinstall your front wheel
How to remove and reinstall your rear wheel
How to remove and remount your tires
How to remove and replace your fairing lowers
How to remove and replace your false tank
How to remove and replace your rear shocks
How to remove and replace your saddle (pannier) bags
How to remove and replace your seat
How to remove and replace your water pump
How to remove, analyze, gap and replace your spark plugs
How to remove, rebuild and reinstall your starter
How to replace the gear oil in your rear drive
How to replace your air filter
How to replace your choke cable
How to replace your clutch cable
How to replace your front brake pads
How to replace your front wheel bearings
How to replace your fuel filter
How to replace your mirrors
How to replace your radiator hoses
How to replace your rear brake pads
How to replace your rear wheel bearings
How to replace your speedometer cable
How to replace your throttle cables
How to replace your windshield
How to synchronize your carburetors
How to tell the age of your tires
How to use a motorcycle lift
Polishing Diamond Plate or Aluminum
Rebuilding your seat
Replacing your fuel pump
Winter Storage Guide
Great Job on your how to forum, Awsom, this may be asking to much, but i am wanting to change fork oil and add progressive springs to my 92, 1500, maybe some day you could put this up, Thanks and keep up the good work,Gary.
Discussion Starter #27
Well, first I'd have to get a 1500... :) But I will most definitely do one on fork oil and springs on my 1100 at some point.
Yep... gonna need these links also...
Discussion Starter #31
I realized that as soon as I posted that list, it was out of date, as I keep adding more. I now also have a 1500, and so I've started posting for it as well. I'm doing a ton of stuff to my 1500 right now, and I've taken hundreds of pictures along the way - it's going to take a while to write all of them up, but I'll get there eventually.
21 - 31 of 31 Posts
