I think your right, I have gone around and around here with this issue, at this point there's no where else to go but to belt up and try again with throttle open, beyond thatIf they are out of synch far enough it is possible for the carbs to make this happen. Cold and wet on 2 and 4 could possibly be flooding on those as well which could also be the carb.
Were it me, and I am a professional mechanic by NO stretch of the imagination, I would get the timing belts on, redo the compression test with the throttle wide open (after assuring both carbs are opening with the throttle), and proceed from there based on the new compression test numbers. If they come up on 2 and 4 I think I would then look into the carbs to be sure they are synched and adjusted properly.
the thought of parting out a beautiful bike is a terrible outcome. thanks.
