OK gents I need an electrical wizard to guide me here. I have a 1985 Aspy with electrical problems that just came up.
I recently finished changing out my sump and oil pumps. Everything went back together easily enough. After reinstalling the motor, starts and runs great, I changed out the side marker lights the PO had installed with a couple of LED lights. I'm not positive but I believe the power for these lights come from the front marker,turn signal lights.
On my first ride taking my wife with me I went to add some air to the rear and found that not only is the pump not activating there's no indication in the control panel of the shock(s) pressure. Due to weather around here I have only been starting it every few days. The last time I started it I noticed the indicator for "No Tail Lights" on in the control panel and sure enough none of my tail lights are on as well as the front marker/turn signal lights. Brake lights, turn signal lights and emergency hazards all work as well as the LED side markers.
Anyone run into anything like this?
Any ideas are much appreciated,
Blessings!
TxWN
Blessings!
TxWN
