1 - 11 of 11 Posts
Token Canuk
Compressor will not inflate. Key in "P" press "Pressure Check" hear a click in the rear, reading low, press "Increase" & nothing. Does it HAVE to be on the center stand ??
Is there a manual way of increasing the rear shocks ??
Have you checked the #7 parking fuse? There quite a few other things but start there. The switch does have to be in park but it does not need to be on the center stand for the compressor to work.
Never mind, I read the diagram wrong. Check the #6 fuse and it can be in the on or acc position to work the pump.
Token Canuk
Thanks Dave, I'll check this morning, if the fuse was bad would the Check Pressure indicator still work ?
if the relay is clicking check the conections from air distribution unit they are on top of the rear mudguard just had the same problem with mine cleaned these conections and everything is working fine now
Yes it will.
Hey 96Aspencade
Just had issues with my 95 1500 air compressor, check fuses 6, 7, & 10....I cleaned the connections to the compressor under the seat on top of the fender, cleared up my issue(pump would not run). Manual claims you get the most acurate pressure reading while on the center stand but I think it's all relative side stand or center. Whichever way you adjust pressure side or center stand you're just using the psi for a scale to see what pressure you are most confortable with and to match your riding preference. Good luck
Token Canuk
Thanks Indianrider, I'll have a chance in a couple of days to get back to it & I"ll post my success. Gonna be a little sore after a session with a surgeon tomorrow for a bit.
It only has to be in "P" to use the outlet hose. Put it on the centerstand and start it up. Should be able to increase pressure simply pressing the "Increase" button.
If the compressor still doesn't work, then check fuses and connectors.:waving:
Good luck with the surgery, eh!:D
Token Canuk
Finally - right SB, works while bike is running & even better if plug under seat is CONNECTED, thanks for all the ideas' :waving:
Even a blind squirrel finds a nut every once in a while!:action:
Glad you found the problem.
Token Canuk
Discussion Starter #11
Ya & can't for the life of me figure out How it got unplugged :gunhead::gunhead:
1 - 11 of 11 Posts
