1 - 3 of 3 Posts
Need help. Trying to get the compufire into my 88 wing and am starting to see stars. What is the magical secret to getting it to fit? :X
Walk away for awhile. Have a Coke (or your favorite beverage) and go back at it. I installed mine last summer and it took me a little over an hour and a half (Coke break included) to finally wiggle that damn thing in. It is slightly larger than your OEM and it is a tight fit. I just kept fooling with it and it finally slipped right in. Just keep at it.
Mike
Senior Guru
Hi dont connect the battery lead at the back untill you have it in place and make sure there is nothing fouling at the back you would have got the instructions that says you fit it in backwards then turn top hole to the five oc position iam so used to it i can swap alt in about 5min flat
1 - 3 of 3 Posts
