1 - 9 of 9 Posts
1997GW1500SE. Motor Trike. Elec problem? Bike will start, headlights, tail lights work, turn signals, hazard lights, “R” comes on but when I put the reverse lever on I blow a 15A fuse in the fuse box . I have tried to check every connection and looked for shorts etc. I do have a light bar and led trunk lights that were on the bike when I bought it. Totally blown mind!:frown2:
Which fuse is blowing? By number, top to bottom. There are more than 1 15 amp fuse in the box.
I see no way putting it in reverse could cause that fuse to blow.
New Sidecar guy
With a trike conversion who knows what was done?
Took me many trips to forums before I found my rear Master cyl. reservoir's hiding spot.
Magic Moderator
By chance did someone add a set of back up lights to the trike? I know it sounds odd but people have done it.
New Sidecar guy
I have seen a back up light on a sidecar rig.
:rofl:
I like that. Maybe I'll rig one, for "Sh*** & Grins* with the group? Wire it through a relay.
The few times I've used reverse on ours, if "Wife Unit" was on board, a "Beep Beep" could be heard.
1 - 9 of 9 Posts
