Folks,
I'm looking to upgrade the headlight as well as the driving lights on my 98SE.
I've read many of the posts on here about the headlight upgrade and do not seem to sense a direct answer to which bulb to get. For the Head light I want to use a 55/60 bulb but I want the brightest whitest bulb that is easily located and affordable aka cheap! BEST BANG FOR THE BUCK! Oh yeah! what's the deal with needing shims to replace the factory bulb? Is the factory bulb not use the industry standard base or what??
On the factory driving lights, has anyone ever tried converting the factory dual filament 18watt bulbs, that only use one filament, (I bridge the contacts with solder one the first filament blows out so I can use the other filament.)
I'mwondering what the limitations of the factory housing is if upgrading to a 35W halogen bulb? Can the wiring handle it? Lens, housing?I'm sure its been done before but what was the outcome? What bulbs, were used and was it worth it?
Folks,
