Hi all,
I should point out right off that I don't yet have a decent manual, so I'm unsure of how the wiring is laid out.
I've a '93 1500 Aspencade which is US spec, and I need to change it to UK spec before the MOT.
The main problem is the indicators which are on permanently while the bike is running, and then they flash when you hit the switch.
I need them to be off and only come on while indicating.
Just wondering if its 2 wires or 3 that feed these lights, ie, are there 2 wires, one of which is connected to a flasher unit, or are there 3 wires and the third comes into play only while indicating to increase the voltage and brighten the bulb.
Also tied in with this are the clear running/cornering lights either side of the mudguard which remain off until indicating, then they come on until the indicators are switched off.
I'm not sure whether Uk Mot centers will accept lights like that or not, so I was wondering if the indicators use 3 wires, would it be possible to disconnect the one providing the permanent power, and use this to feed the running lights instead so that they're on all the time instead of the indicators, basicly reversing the functions of the lights so the indicators are off instead of on, and the running lights are on instead of off?
Hi all,
