1 - 3 of 3 Posts
Hi Guys, need some insight as WHERE to hook up electric fuel pump!! I did a search, but really came to no conclusions where would be a good place! I've read to use an oil safety switch and also to hook up on the starter solenoid, both on the "P" terminal which neither one have!! I was wondering if anyone who purchased Randakk's pump conversion would tell me where he connected his!! Thanks Bob
If it were me, I would attach the positive wire to the switched accessory terminal on the fuse box under the false tank, and find a good ground on the frame.I am almost positivethis terminalis switched to the key. I do not have my battery in right now as my bike is stripped, but can other GL1100 owners confirm ?
Remember that this will pump whenever the key is on, so if you are a "kill switch" guy like I used to be, the pump will continue to run, and could fill your engine with gasif you forget to close the petcock each time you stop!!!! I like the oil-pressure switch idea because the pump would quit when no oil pressure.
· Village Whack Job...
I would use the accessory terminal for positive through a relay that was switched by the oil pressure sensor. Now a typical relay won't work you would need a single post double throw relay.
1 - 3 of 3 Posts
