The front brake light switch is bad and not available. The only option I know is to up grade to a newer brake system. I asume Iwill need the lever and master cylinder and hoses and spliter block and calipers and hoses. Does any one have any advice?
i think you should be able to match up the brake switch at napa. its just a standard 1/8 pipe hydraulic brake switch i believe. jb
Village Whack Job...
Um...I think you could get away with just switching out the master cylinders. That is if you can't find a switch.
:waving::waving: Welcome to the World's Greatest Goldwing Site rclawton! :waving::waving:
There's one on eBay at the moment. You might be able to save a couple bucks asking him to ship just the switch if you won the auction.
eBay brake switch
you don't say where your are located.
In uk you don't need a front brake light switch if you tape up the wires for the MOT test. The rules here are it must work if fitted. If not fitted and therefore absent you don't need one.
Just out of interest I needed to change mine every year for the MOT test as it would always go wrong. The 1980 gl1100 was very prone to water getting in. The switches were cheap enough but it got to be an annual pain and I got rid of it.
