I just got this trike .Couldnt test ride because clutch master cyl leaked real bad .Started up no problems but was pouring gas out under air cleaner .So I rebuilt carbs new clamps on all hoses for gas and water at carbs.Now I could run it .Still no clutch but can start and let run .Filled radiator and started .Ran good then started running rough .Saw leak out of small hole in left tail pipe .no cross over or mufflers straight pipes .its a trike .Took a few minutes but warmed up to half way on temp gauge and stayed there .I let run 10 min or more still had drip out tail pipe . Shut off let cool down and pulled plugs on left side .Did look in radiator before while warming up no bubbles .plugs were all dark and fouled had film like coo lant on all 3 . Question is there a coolant line hooked to intake manifold that could leak coolant into all 3 cyl?
