Hi everyone,
I have a question about my 1998/GL1500SE cornering lights. One of the bulbs is burnt out and I removed it. Can't find a replacement anywhere! It is a 12V 18/18W. Anyone have a source for these bulbs?Is it best to stay with the 18Watts or can you put in somthing higher? Thanks as always!
Mike V
I might be mistaken, butI think you can get 23 watt items as well. They will probably end up melting the housings though.
I have a 98 Goldwing SE. I tried your sugestion about turning the cornering light around but I've found that the lights will only fit in in one way because of a tab on the light housing. I'm having difficulty finding replacement bulbs and the dealership wants over $20 bucks for one...
dmpi
I had to replace one and i got it at Canadian tire for 3 bucks.It was a bulb from an old skydoo.I brought the old one in and they matched it up.
Also i believe that you can remove the part with the tab and reinstall it on a new bulb.I didn't have to because the bulb fit properly
