Over the weekend I decided to check out the carbs on my 1500. Got everything ready, tools, vacuum gauges, plugs while I was in there, air filter etc. (It has been extremely hard to start)
Pulled the side covers off, the radio off, anything else I needed as the accessories (lighting) had stopped working also.
I changed the air filter first, then went to check the balance on the carbs and I found some difference on my bike and the pictures in the forum. On the right side where you are supposed to take out a screw, put in an adapter and then hook up the gauge I found a vacuum hose already hooked up to the right side carb. Close inspection disclosed a small hole in the hose. Checking the left side showed a hole in that side in about the same place on that vacuum hose. I repaired them both and hit the starter. It immediately fired and ran real steady. Checking the carb balance showed them to be perfectly balanced.
Since the repair it starts instantly, with no playing with the choke lever or anything else. Just hit the starter and it starts almost instantly.
On the lighting I found a large ball of wires behind the left pocket that contained three relays and a wire had worked loose on one that put everything to ground. Everything is working now.
Just thought I would post this as a small hole in the vacuum can create havoc with starting.
