Crack in Exhaust valve
743 Views 8 Replies 6 Participants Last post by  mzandmywing
One of my exhaust valves has a crack in it Need a used one now. If any one has a good used one I will take it. The place online is out of stock and there arnt any on Ebay. Please help me .......:(,:shock::(,:?,
1 - 9 of 9 Posts
GL1100 uses the same valves if thats any help.
E-bay #170379954011. 1000cc cylinder heads complete. Hope this helps, Tony:waving:
GL1000 and GL1100 exhaust valves are identical. Prices new vary from $45-$60, Saber-Cycle has them (OEM) for $45 each- http://www.saber-cycle.com/store/product331.html
Partsnmore also list them for $15 but I'm not sure if they are OEM (it says OEM ref). This is the description;
"Fits GL1000 (75-79) & GL1100 (80-83)1Made in Japan1OEM Ref. 14721-371-000"
Its about halfway down this page;
https://www.partsnmore.com/cat_index.php?model=gl1000-1100&category=engine
EDIT: Sorry guys its showing as "out of stock" when you click the link for more information.
Yep Parts-N-More OUT OF STOCK. Found a sourse. USED is ok CYCLEPYSCHO in Eugene OREGON. 125 miles away has 4 and just sent them says to me only have to pay shipping($5.00) should be here tomorrow.Pay later he says. What A guy. Thank you for people like that.
Where on the valve was the crack?
That's a good question. Was the head already off and you discover a crack?
Yes I am doing upper end restore. Preventitive maintianance. New gaskets,new timing belts New valve seals and lapping valves. And thats when I noticed an exhaust valve with a couple cracks starting to run from the outer edge. Lapping wasn't making them go away,A good sign the valve is starting to wear/or burn. Cracks sometimes appear from heat causing it to start to burn the valve face.
1 - 9 of 9 Posts
